Driveline Angle?
Old May 4, 2010 | 09:45 PM
Disturbedpony's Avatar
Driveline Angle?
Just got done installing my 2/4 eibach kit and carrier bearing kit on my 04 screw. I have looked for the driveline specs so I can make sure everything is good to go before I make a long trip. I only get a small vibration at around 54-58 mph but I think it might be a tire issue but I still need to check the driveline angles.
Thanks in advance
Old May 5, 2010 | 08:44 AM
Carlsson3's Avatar
You might want to try your question in the Street Scene section of this forum. I had the Eibach 2/4 put in, and since my '07 has a 2 piece DS, I had to install a Ground Force CB re-locator. Vibration is 99% gone. It only occurred at low speed while accelerating from a stop. The angle is probably pretty close to where it should be, but exactly correct–probably not.
