35's on stock rims
Old Apr 8, 2010 | 09:51 PM
Jarett R's Avatar
35's on stock rims
Hey guys just wondering really quick if 35 x 12.5 fit on stock 17's not the chrome ones but the silver. I did do a search but couldnt come up with a deffinate answer. Thanks a head of time.
Old Apr 8, 2010 | 09:54 PM
Maxout05's Avatar
depends on the tire style as to whether it will work with no issues. for example toyo mt's have huge side lugs and rub badly at lock, where as the bfg muds dont rub anywhere in the same size. You will for sure need to level.
I personally would highly suggest 295 70 17's as they are cheaper in this side and also fit better, but look very close to the same.
Old Apr 8, 2010 | 10:15 PM
Delgaty's Avatar
I was advised that the widest you can go on a stock rim is 285, any bigger and the sidewall will rub on the spring itself.
Old Apr 8, 2010 | 10:24 PM
Maxout05's Avatar
again then depends on the brand/type of tire you go with. Some companies 35's are really narrower then other for example. also depends on rims you use.
Old Apr 8, 2010 | 10:27 PM
Jarett R's Avatar
The tires are(dont laugh i'm getting them really cheap from a buddy) Kelly Fierce Attitudes if that helps.
Old Apr 11, 2010 | 07:03 PM
Jarett R's Avatar
Old Apr 11, 2010 | 08:13 PM
jdruzik's Avatar
You will have some rubbing and have to do some trimming with 35x12.5" tires on stock wheels without a leveling kit regardless of the make of the tire...
Old Apr 11, 2010 | 08:38 PM
You can fit a 35x12.5 on a stock 7 1/2"wheel but it has to be on a leveled 4x4 to work. They still may rub when making hard crank's. An all terrain tire has better chances not to rub then a mud tire.
Old Apr 11, 2010 | 08:46 PM
jdruzik's Avatar
Most 35" tires require a minimum of 8" wide wheels. Stock 7.5" wheels is risky...
Old Apr 11, 2010 | 08:50 PM
Maxout05's Avatar
I dont think you can fit them at all without a leveling kit at least. I have a 2" leveling kit and had that with my 35's.
Old Apr 11, 2010 | 11:18 PM
hawg_man's Avatar
Old Apr 12, 2010 | 09:07 AM
Jarett R's Avatar
Originally Posted by hawg_man
I ordered a 3" leveling kit from readylift and am planning on getting an add a leaf. Do you think the add a leaf will level it out with the 3" in the front or will I have to add a block in the back too?
Old Apr 13, 2010 | 06:56 PM
Jarett R's Avatar
Also do you know who sells the add a leaf can I get it from any suspension company ive looked around but suck with this internet business?
Old Apr 13, 2010 | 07:05 PM
streetassasin's Avatar
I got my add a leaf from fat bobs
Old Apr 13, 2010 | 08:23 PM
Jarett R's Avatar
Thank you! I actually just ordered the 3" block from readylift where i got the leveling kit. Cant wait to get them both and my 35's! hopefully by the second week in may it will all be done!
