Reverse Lights Don't Work
Old Apr 6, 2010 | 08:27 PM
jwr689s's Avatar
The reverse or backup lights aren't working on my 04 scab. The bulbs are good and I also checked the no.14 fuse as well as a bunch of other fuses and they are all fine too. I checked the wiring from the tail lights back to the transmission and I couldn't find any cuts, breaks, or loose connectors, etc. Does anyone have any suggestions of things to check? I did a bunch of searches on the forum but only came up with reverse light mods. I'd appreciate any help.
Old Apr 6, 2010 | 09:35 PM
FX4 Matt's Avatar
Registered User
Did you check for volts at the rear light bulbs? a volt meter will save you
Old Apr 6, 2010 | 09:40 PM
jwr689s's Avatar
No, I just looked at the bulb filaments. I'll check for volts tomorrow and report back.
Old Apr 7, 2010 | 03:54 PM
jd2518's Avatar
I have the same problem...also, my trailer lights dont work...could these be on the same fuse???
