FIX: 45 - 60 mph shake
Old Apr 6, 2010 | 09:00 AM
gataeagles7's Avatar
On mobile so cant pull up my old thread. I found a fix for the 45 - 60 mph shake that so many of us have. REMOVE SPARE TIRE AND REAR BUMPER. Im replacing my rear bumper and i pulled the spare out from the bottom and the shake is gone. unfortunately this is a temp fix. just thought I'd share.
Old Apr 6, 2010 | 09:25 AM
ChrisAU's Avatar
60% of the time, it works every time.
Seriously though, how in the world could that be a cause?
Old Apr 6, 2010 | 09:34 AM
motograter's Avatar
lol, sounds like sex panther by Odeon.
it's most likely a wheel out of balance or an alignment issue, and just a coincidence that this temp fix worked. maybe the weight of the spare & bumper was adding to the problem ... but the problem is probably still there.
Old Apr 6, 2010 | 09:59 AM
For sure it's only a temporary fix. I can't ride around forever without those parts. I have a new set of Monroe shocks to put in the rear to see if that fixes it. I'm going to have them installed when I decide on the wheels & tires I want.
Old Apr 6, 2010 | 10:26 AM
LateKnightRides's Avatar
99.9% of all percentages are made up. Maybe even this one. who knows. ;D
But isn't it illegal to not have a rear bumper system in place? or is it just the front bumper you need. Even if the front bumper is a 2x4.. would it be the same for the back?
Old Apr 6, 2010 | 11:17 AM
kingfish51's Avatar
More than likely he still has the vibration, just that by changing the weight on the frame, he changed the resonance point that it would be felt in the cab.
Old Apr 6, 2010 | 11:27 AM
Technically speaking, yes. You are probably 99% right.
Old Apr 6, 2010 | 02:58 PM
sonic69's Avatar
So if he takes off his bed...........
Old Apr 6, 2010 | 02:59 PM
Please do not challenge my OCD
Old Apr 7, 2010 | 05:25 AM
code58's Avatar
Looks like you took some slightly immature heat for what you shared, but I for one appreciate it! Have never heard of that before but it may lead to a solution that does not necessarily involve the removal of those parts, but will give someone a lead for a fix for a problem that even Ford has never seemed to be able to completely cure.
