steering rack knock
Old Mar 31, 2010 | 07:57 PM
bed rock's Avatar
Post steering rack knock
Hi guys i have a 04 4x4 i heard a knocking noise when you move the steering wheel back and fort i thought it was the outer or inner tie rod end. I went out today to check out the knock and it was not the inner or outer tie rod . I got my father to move the steering wheel and i could here the knock on the driver side in by the rack i moved the boot back and when father moves the steering wheel the shaft coming out of the steering rack got play. Is there a bushing or bearing in there that could be worn that i can replace or is that normal i dont think. Do anyone know where i can get instrucions on how to rebuild my rack.
Old Apr 1, 2010 | 12:30 AM
thorherc67's Avatar
i have the same problem
Old Apr 1, 2010 | 02:18 AM
08stx4x4's Avatar
I just had my truck into the dealer a few weeks ago for this problem.
It turned out to be The Stabilizer End Links (Part #: 5L3Z-5K483-DA). They replaced both of them and the noise is gone now.
Stablizer Links From Tasca
Here's a pic that I took. It's the part with the blue 4x4 sticker on it.
Mine had disconnected from the Lower Control Arm and was just rocking up and down and the clunk noise occurs when it makes contact.
Old Apr 1, 2010 | 07:25 PM
bed rock's Avatar
Thanls a lot for your help that is the problum with mine.
Old Apr 1, 2010 | 07:27 PM
bed rock's Avatar
sreering knock
thanks guys thats the trouble with mine
Old Jul 14, 2010 | 02:15 PM
tmd07's Avatar
Just wondering if you have solved this? I have the exact same problem. My driver side inner tie rod (I think it's the inner. It's the shaft coming out of the rack under the boot) has play also and I can actually move it up and down a little. I started noticing it when I was getting feedback to the steering wheel over bumps.
