Steeda underdrive
Old Mar 5, 2010 | 06:01 PM
youngjyg's Avatar
Steeda underdrive
I just got a set and wanted to know if any one installed them and how hard it was or will be?
Old Mar 5, 2010 | 07:54 PM
Windsor's Avatar
I haven't installed an underdrive pulley but I had to remove my pulley because of my supercharger. The hardest part is getting your hands on the right tools. The crankshaft pulley on 2007-ups do not have the three threaded bolt holes that most harmonic balancer pullers could be used to remove. OTC makes a puller that doesn't rely on the bolt holes. You could try some of the auto part stores that rent tools. You may have to remove the fan and shroud for clearance. I had to anyway, but I'm not sure you'll have room to work with the fan and shroud in the way. The fan is going to take a special tool to remove as well. Beyond that it's a matter of removing the belt and installing the new pulley. If you have other pulleys with the kit, I can't help.
Old Mar 5, 2010 | 10:35 PM
8up's Avatar
8up
Go to any parts store ( tell them what your upto )and rent a 57mm spanner to hold the fan pulley at the screws, then I used a 1 1/2 oppen end wrench to lossen the fan.
If you dont allready have one youll need a shorter belt, 1" I think.
Old Mar 5, 2010 | 11:25 PM
youngjyg's Avatar
i dont think i need a new belt from what ive seen from steeda but ill look into it thanks
Old Mar 6, 2010 | 08:36 AM
Big Slick's Avatar
where did you buy them from? I don't see any parts for f150's on their website.
Old Mar 6, 2010 | 09:58 AM
youngjyg's Avatar
there for the 05-10 mustang gt i called them and they said it works
Old Mar 6, 2010 | 10:13 AM
Big Slick's Avatar
oh, i guess you have a 4.6 then?
Old Mar 6, 2010 | 10:55 AM
youngjyg's Avatar
nope 5.4
Old Mar 22, 2010 | 12:02 PM
youngjyg's Avatar
ok they are on the water pump pulley was a little bit to big so i had to grind some from the block took 3 secs and i did need a new belt and they work great now
Old Mar 22, 2010 | 11:15 PM
Jughed's Avatar
What Part numbers from steeda did you use? if you dont mind. Was about to order mine from Troyer and would like to compare before i buy.
Old Mar 23, 2010 | 09:02 AM
Big Slick's Avatar
awesome. any performance difference on the butt-dyno?
Old Mar 23, 2010 | 02:44 PM
youngjyg's Avatar
butt dyno says yes and the ear dyno with the off the line burn out is alot longer too have not seen any mpg yet but i also have been driving like a bat outta hell
