Salt
Old Mar 2, 2010 | 04:07 PM
DarkShadowSTX's Avatar
Salt
Look at all this salt buildup and crap in my engine bay! What is the best way to clean it off without ruining anything? Please help. Thanks
Also what is this part that has become so rusty after less than a year and a half? I can touch the round part that has all those little tabs and rust falls off.
Old Mar 2, 2010 | 04:13 PM
W.L.B's Avatar
WOW! Looks like a rag and some engine cleaner are going to be your friend. I washed my engine once and fried my TPS.
ROB281's Avatar
simple green & a s**t load of rags
Old Mar 2, 2010 | 04:14 PM
Turd Furguson's Avatar
If you are going to do anything at all, cover up your COPS before you wash anything. That will be the first thing that will make you do a face plant after you drive your truck shortly from the engine bay cleaning. These COPS die quickly if any water or moisture gets in them from spraying.
Old Mar 2, 2010 | 04:43 PM
I didn't even realize it was this bad until today when I changed my oil. It was at the dealer yesterday to see if I needed a reflash or TB because of a code issue and nobody told me about this s**t.
Old Mar 2, 2010 | 04:48 PM
Ricky Bobby FX4's Avatar
I hate salt
Old Mar 2, 2010 | 06:55 PM
FX4Screwdude's Avatar
Ok stupid question of the day, whats the COPS and where is it? Just in case I decide to clean in there someday Ill know...
Old Mar 2, 2010 | 07:01 PM
Silver04f150's Avatar
if that was my truck, i'd get the hose and spary it down quick while its running
Old Mar 2, 2010 | 07:30 PM
risupercrewman's Avatar
Dude thats nasty!
Old Mar 2, 2010 | 07:39 PM
gcart's Avatar
yea i have sprayed mine down once or twice. wd40 is your best friend in that case.
Old Mar 2, 2010 | 09:47 PM
avfrog's Avatar
Car wash, for sure!
Old Mar 3, 2010 | 09:26 AM
wolverine08's Avatar
Best way is a bucket of water with a small amount of detergent and rags. Don't soak the rags, wring them out pretty dry. You can wash the underside of the hood, front near the radiator if your careful. You may go through a few fresh buckets but really it isn't that bad.
Don't high pressure wash your engine, it would almost be better to leave the salt film on.
Old Mar 3, 2010 | 11:45 AM
Good morning to you sir!
COP»Coil on Plug.
Instead of having a single coil and a distributer these motors have individual coils on each plug controlled by the PCM.
PCM»truck's computer.
Some people who wash their motors end up with problems afterwards. Especially when using pressure washers.
So what they are trying to say and did is to take precautionary measures to make sure that the area(top) on the motor doesn't get wet.
Just thought I'd pass that info along to help keep you more informed!
Have a great day!
Peace
Old Mar 3, 2010 | 11:57 AM
You sound like MGD 88
Old Mar 3, 2010 | 01:39 PM
fivespeedsteed's Avatar
ive typically covered bunches of electronics and juts used a garden hose with no attachment and not on full blast. just kind of a steady little stream, maybe about a half inch in diameter. i usually soak it in mean green too. make srue you cover the 4wd iwe thing, the cop's and whatever groups of electronics you find
