"Trans Fault" Wrench Light too! Bad news or glitch?
Old Feb 26, 2010 | 06:58 PM
edgespeeder06's Avatar
So I was trying to move my truck out of 2.5 feet of snow and it was doing find til I saw my small display say trans fault and the wrench light pop up? only has 59k
Now I shut it off and turned it back on and works fine now.....should I be worried? Anyone seen this before?
Old Feb 26, 2010 | 07:00 PM
sampson01's Avatar
was the truck moving at all??
Old Feb 26, 2010 | 07:16 PM
bjp207's Avatar
If the tires are moving real fast and the truck isn't, aka doing burnouts it'll go into failsafe mode, dunno why trans fault popped up though
Old Feb 26, 2010 | 07:26 PM
Watson91's Avatar
Mine did that in the snow one time. Went out to the local airport, and was turning around in their parking lot got stuck. Ended up getting some wheel speed and the wrench came on and truck started running funky. Shut it off, turned it back on and no problems since. That was about 20,000 miles ago.
Old Feb 26, 2010 | 08:28 PM
Paralyzer's Avatar
im guessing you were stuck and trying to rock yourself out? it should be mentioned that doing exactly this wrecks many transmissions. the transmission has a built in temp sensor. you most likely overheated your transmission, greatly reducing its lifespan...i would change the fluid asap. any damage that has been done is now irreversible.
Old Feb 26, 2010 | 09:51 PM
ah nope, 4wd was fine! It just did it when I was pulling out of the spot but no wheel spin nor did i smell anything funny. I'm hoping its fine. If not I will get it checked out.
Old Feb 26, 2010 | 10:28 PM
Tbird69's Avatar
My '04 did this about 6 years ago. I was backing out of my garage, the wrench light came on and it started running rough. I shut it down, then restarted it, the light was off and it ran normal again. Hasn't happened since.
I wouldn't worry about it.
Old Feb 27, 2010 | 11:30 AM
I'm betting that a sensor's wire or plug got wet from the snow.
I'd say you are fine.
Then again, the last time someone asked me what the wrench light meant in a F150, I told them that a mechanic left their wrench in the engine.
Old Feb 27, 2010 | 04:22 PM
Nico's Avatar
Most likely a computer glitch, probably not a big concern. My work van does that sometimes. It will act funny then start holding a gear and not shifting. I shut if off and its fine. It does it every so often and has not caused a bigger problem.
I doubt it was heat, I plow with my truck for hours on end and I don't have issues with trans temps. I was out all morning and my truck never even hit 170' Normally I am in the 150s when plowing and the 160s while traveling with the plow. My trans runs hotter when I tow then when I plow.
But if your at 59k and never had a tranny service done, it would not hurt to get the fluids changed. I run royal purple in the trans, t-case and both diff's and I did notice the trans temps dropping by about 8' after the switch. That could be the diffrence between a new tranny sometimes.
Old Feb 27, 2010 | 08:30 PM
DarkShadowSTX's Avatar
It has happened to me probably 3 times. I would be pulling out of my driveway and it says trans fault. My truck never started to run weird or anything but every time I just shut off my truck, restarted and then had no problems after that.
Old Mar 1, 2010 | 08:31 AM
well guess what I had it serviced at 40 something when I bought it.....tranny may have just crapped out.
*barely no power in the forward gears, can't get it passed 20mph and seems like reverse has all the power* -- same thing that happened to my dads 2000 windstar before he had a new transmission thrown in. Code Po731 So how f-ed am i?
Old Mar 1, 2010 | 11:27 AM
Allcarfan's Avatar
THis has happened to me 3 times. Only happens when the trans is cold and when going slowly down a hill. All three times, I just shut the truck off and turned it back on...no problems. Others have had the same issue.
Old Mar 1, 2010 | 08:02 PM
P0731 is a solenoid or clutch failure in the tranny. If it's a solenoid, that's a fairly easy fix, but if it's a clutch it's rebuild time.
Old Mar 1, 2010 | 08:56 PM
ah yeah same thing I read up on and also it missed 1st and 2nd gear which may explain why it wont go up hills....how embarrassing is it to have it a tow bed hook me and pull me up the bed because my v8 had no power lol It sucks but thankfully I found out I have 75k powertrain and they cover $30 for a rental..........they took me to enterprise and the guy said: "I can give you that 09 F150 for the price of a compact car if that helps" $40 a day minus $30 plus $20 for insurance since I drive alot and not sure how long the truck will take to fix....so I got a sweet deal.
I am impressed at how well the mpgs are and how roomie the crew cab is and how well it rides! I could swear mine takes the bumps much harder lol I just want my truck back though
Old Mar 2, 2010 | 01:43 AM
Paralyzer's Avatar
P0731 means your trans is slipping. Forward clutch is likely smoked.
