Broken '04 Rear Sliding Window Bracket
I recently purchased a used '04 Lariat and realized after that the power rear sliding window did not move although I could hear the motor working. Upon further inspection I found one of the cables was hanging loose and that there was a broken end piece of a bracket still attached to it. The glass sits in this bracket and is pulled open or closed by the cables attached at each end. If I manually open the slider it will shut using the power switch. So I narrowed the problem down to the broken bracket but can not seem to find any info on replacing that bracket. Does anyone have any idea how I should go about solving this problem. I hope I don't have to buy a whole new window assembly just for this stupid bracket.
Thanks For Your Help!
Nonsense
Go to a junkyard and find one.
Chances are extremely slim that this part would have been damaged in an accident so you should be able to pull one off a truck for a couple bucks.
Sounds to me like maybe someone broke into his truck through that window and thats why the bracket is bad???
