Custom Shocks Where?
Old Feb 22, 2010 | 12:55 PM
mhockey9090's Avatar
Called bilstein and the only shock that will fit my soon to be 14 inches of lift is a 9100 series listed somewhere around 350 a piece and I can't afford that right now. Right now my shocks eye to eye are like 28inches. I'm not sure what they are fully extended. Replacing my old lift with the new will put me up another 6inches so roughly 34 inches shock mount to shock mount. Now only other option bilstein has is a 14inches of travel with an eye to eye fully extended 34.9 so obviously that's not going to work. But he brought up and idea of moving the shock mounts somewhere else so I could use the 5125 series with 14inches of travel. Any input on this?
Also I see some huge a** trucks with shocks that are cheap looking. You know what I mean by being like plain white? What are some places I could call to order a set to match my specs so I don't have to re locate my shocks mounts? Its just a temp shock so I can drive it to Houston put my truck into storage while I'm in Germany and then get all the high quality stuff for it when I get back.
Thanks Guys,
Josh
Old Feb 22, 2010 | 03:32 PM
thejake1989's Avatar
just run no shocks
Old Feb 22, 2010 | 03:45 PM
gcart's Avatar
why not link two shox together lol.
Old Feb 22, 2010 | 04:12 PM
dilloncawthon's Avatar
i thought you were just gonna run the strut extension and some oem shocks until you could get some new ones
Old Feb 22, 2010 | 04:47 PM
just run no shocks
Gonna have to on the drive home. That's if the driveshaft isn't pulled out way too bad for me to drive 7-8 miles to the house.
Old Feb 22, 2010 | 04:48 PM
This is for the rear. The front is taking care of.
Old Feb 22, 2010 | 04:50 PM
xxdriverxx's Avatar
Check out FOA, they have good low priced high quality shocks. www.f-o-a.com
Old Feb 22, 2010 | 05:04 PM
Thanks for that link. I think ill end up having to go with 18inches of travel.
Where would I get them charged at? How much would something like that cost?
Anymore sites out there?
Old Feb 22, 2010 | 05:30 PM
xxdriverxx's Avatar
For nitrogen charging places, a lot of power sports dealerships do it but any performance/truck place down in Texas should be able to point you in the right direction.
Also Racerunner/SAW at www.swawaway.com And then of course the usual Fox, King, etc.
Old Feb 22, 2010 | 05:55 PM
Thanks man. If you come across anything else just let me know
Old Feb 22, 2010 | 06:14 PM
bankrpt's Avatar
Doectech(spelling?) They built them you can get the with the piggybacks for 160 a piece
Old Feb 22, 2010 | 06:32 PM
I saw they only have 15inches of travel. I guess ill have to find out for sure what the measurements are going to be when I put the lift on.
But keep em coming guys I appreciate this as it will make it a lot easier to get when I put the lift on.
Old Feb 22, 2010 | 07:09 PM
adaniels88's Avatar
Downsouthmotorsports.com tell them Albert sent you.
Old Feb 22, 2010 | 08:34 PM
bankrpt's Avatar
http://www.doetsch-shocks.com/7.asp
8-1800SB compressed 28.00 extended 44.00 travel 18
Old Feb 22, 2010 | 08:38 PM
bankrpt's Avatar
here you go about some cheap shocks
http://www.airbagit.com/Lifted-Shocks-s/1700.htm
