CAL reading above OD...
Old Feb 19, 2010 | 04:56 PM
Mr. eXtreme's Avatar
Hey all, So on my way in to work today I saw that I now have a CAL light above my Odometer??
I assume this is to recalibrate the temp and compass but not 100% sure how to make it go away...
I think I turned it on after getting gas while resetting my trip od...
Also have a flashing check engine light which has come and gone for a couple weeks now??? Ideas... Dropping at dealer tomorrow most likely.
Here's a pic of the CAL:
Old Feb 19, 2010 | 06:01 PM
ian51279's Avatar
On other Ford's I've had you drive in slow circles until the "CAL" goes away and shows direction and temp again.
Old Feb 19, 2010 | 06:14 PM
W.L.B's Avatar
Yep you have to drive in circles less that 5mph I think so it can calibrate the compass. look in your owners manual under compass callibration.
Old Feb 19, 2010 | 07:03 PM
Djacobs28056's Avatar
There is a button on top of that black box behind your rearview mirror. The flashing CEL is indicative of a misfire. If it happens under stress (I.e. you're ******* it) don't worry yet. If it happens while driving normally, time for a tune up. Given the horror stories on the plugs in these trucks and if you have over 50k, I'd go ahead with the tune up.
Old Feb 20, 2010 | 04:53 AM
W.L.B's Avatar
Thats a CEL, he is talking about CAL.
Old Feb 20, 2010 | 08:33 AM
Thanks guys, CAL light is gone... IDK how it happened but after backing out of my driveway late yesturday and leaving it went away... I do live in a circle.
I also had that ? about the CEL check engine light though.
Thanks for the heads up on that. This button by the mirror what does it do?
