Rough Idle - I think
Old Feb 11, 2010 | 09:26 AM
KPIC's Avatar
I have a 07 Lariat with 5.4L. Has 47k miles.
I just bought it and its the first 5.4L I have owned. Is the idle suppose to be whisper smooth or feel like its missing a bit? Mine feels like its missing abit. Nothing too bad. It starts fine, runs good as far I know. My previous truck was a Chevy Suburban with 5.3L that was whisper smooth, so I notice the rough idle in my Ford.
Old Feb 11, 2010 | 01:18 PM
Trilandun's Avatar
I would check / change all the usual items:
- Change Fuel Filter
- Change Air Filter
- Consider having the plugs replaced
- Run a quality injector cleaner or get an injector cleaner service (after fuel filter change)
- Clean the MAF Sensor
There is a lot of info on these topics on these forums if you use the search function.
Old Feb 11, 2010 | 03:17 PM
mellowyellow's Avatar
you can check your throttle body too it may need cleaning.A dirty throttle body will cause a rough idle as well
Old Feb 11, 2010 | 05:46 PM
abnpacrat's Avatar
I've had an issue like this twice and it ended up being an issue with a spark plug on cylinder number 3. It didn't seem to hurt the performance much, but it idled a little rougher then usual.
Old Feb 11, 2010 | 06:19 PM
f this's Avatar
I've got the same truck. Mine seems to shake a little at idle. It doesn't run funny in any way, no skipping, no stumbling. It idles steady but every once in a while while idling I will feel a little shake. I wonder if it's the same. My 4.6 never did this.
Old Feb 12, 2010 | 06:41 PM
TICKINGTIMEBOMB's Avatar
My 05 does it too.
Old Feb 12, 2010 | 10:31 PM
KPIC's Avatar
Took it to my buddy today. He changed out the fuel filter, cleaned out my throttle body and told me that my air flow sensor had some K&N oil on it. So he did his best to blow it out.
$50 bucks for his trouble and it runs noticeably better.
Old Feb 13, 2010 | 12:23 PM
avfrog's Avatar
^ did you over oil your K&N Filter?
Old Feb 14, 2010 | 07:59 AM
bambo2888's Avatar
hmm, interesting... seems like a logical potential culprit for me too.
Old Feb 15, 2010 | 06:06 PM
KPIC's Avatar
I didnt install it. I had a truck accessories place put it in for me and it could be that they over oiled it. My buddy said that it needed a good wiping off when he looked at it. After a week of driving it, idle is as smooth as silk and got 19 MPG on my last HWY trip.
