weird thing happened
tonight its raining and on my way home i came to a complete stop and hammered it my tires broke loose and was spinning it went from 1st to 3rd gears and when it hit 3rd the motor popped and the tool light came on so i pulled up to the house and used my sct to pull the code but there was no code and when i started the truck the tool light went away any suggestions way
my truck is a 04 5.4 3v, sct tuner, jlt intake, banks 3.5" exhaust, rear cats deleted, efans,
Normal - you hit the no/low load over-rev limit - (vehicle speed versus rpm mismatch over time) and pooped into failsafe/limp-home mode. Hence the "Hey, ya Toolbox .." icon on the dash.
Clears on next startup - hopefully.
Don't Do that, okay?
Short bursts are okay - it's when the event is prolonged and/or extreme ( in yer case across shift points) that the PCM stops the fun. I can trigger it at will playing in the snow.
You would have to ask a tuner this question.
I'd leave it alone - it's there for a reason.
Oh you're burning plenty of fuel, along with tires and other things. You live up to your name.
