Caliper Bleeder Broke ??
Old Jan 18, 2010 | 09:04 AM
duckduke's Avatar
The brake fluid bleeder on one of my rear calipers broke/sheared off about even with the caliper.
The remainder of the bleeder is in the caliper.
What's the best way to resolve/fix?
1) Use an easy-out to try and remove??
2) Replace caliper??
Any suggestions would be appreciated. Just trying to see if there's something I'm not thinking off. I don't think the easy-out will remove. A new caliper is the only way I can see to resolve.
I'm preparing for a rotor and brake pad change. Wanted to flush/replace the brake fluid ahead of the change.
Loosening the bleeders at the calipers always seems simple but a huge PITA for me. The bleeders always seem difficult to loosen (which is a good thing when their in..........but a PITA to loosen).
Thanks again for any suggestions!!
Old Jan 18, 2010 | 09:58 AM
ford norseman's Avatar
Had this happen before. Solution I used was step 1, if that didn't work, go to step 2. Good Luck!
Old Jan 18, 2010 | 10:42 AM
Since it is part of the crucial braking system... I'd replace the caliper... It's not worth it losing hydraulic pressure and losing control of your truck. It's like $500<$25,000 and all the hassles.
Old Jan 18, 2010 | 03:04 PM
bjp207's Avatar
the stock calipers are garbage as it is, might as well replace it while you have it off, they arent that much money
Old Jan 18, 2010 | 03:11 PM
arubba's Avatar
FYI,,,, if you replace the caliper with other than a STOCK one, replace both as a pair.........
Old Jan 18, 2010 | 05:00 PM
duckduke's Avatar
What a huge aggrevation!!!!!
I've been to 1 dealership 3 parts stores........called a couple of other dealers and parts stores...............no bleeder screw.
Even if I can get it out.............it appears buying a caliper would be easier.
All for a $3 bleeder screw.
