78k miles, suggested maintenance
Old Jan 16, 2010 | 07:14 PM
Gunmetal06's Avatar
What would you guys replace or service aside from what the owner's manual says? 78k miles, 5.4 3V 2006 F150 Super Crew 4x4
Brakes will be changed since they are starting to squeak. I see a lot of people get the Ultraquiet Ceramic type pads. These any good?
I'm sure the plugs haven't been changed, nor am I in a hurry to change them seeing how big of a PITA it is. COP's seem fine too. I plan to run some cleaner through the system too.
I'm basically looking to see what other little quirks that should be checked before they become a problem down the road.
Thanks in advance
Old Jan 17, 2010 | 01:32 AM
drunderw's Avatar
Check out my post that is similar: https://www.f150online.com/forums/20...10k-miles.html
Fuel filter isn't hard to do. http://personal.davidunderwood.org/?p=81
Old Jan 17, 2010 | 02:05 PM
05BlackFX4's Avatar
At 65K I flushed tranny, brake fluid, power steering fluid, rear diff and will be doing my 4x4 transfer case fluid. Inspect brakes like you said and have battery tested. I will also be changing my fuel filter here shortly.
Old Feb 17, 2010 | 09:59 PM
RCB06SC's Avatar
What transfer case fluid are folks recommending?? I have 65K and time to do it.........
Old Feb 18, 2010 | 12:37 AM
Any ATF that meets Mercon V specs.
Old Sep 11, 2010 | 08:02 AM
two dawgs's Avatar
how do i change fuel filter in 2008 f150, do i need a special tool to get fuel filter off?
Old Sep 11, 2010 | 01:34 PM
Svets96's Avatar
I just got a letter from my dealership, to what service they recommend. At 78k you would need, tranny fluid inspected, brakes shoes, linings, hoses, parking brake, inspect engine coolant and hoses, inspect and lubricate all non sealed steering linkage, ball joints,suspension joints and half, and drive shafts, plus u-joints. If you go to Fordowner.com they have an owener advantage rewards program. You sign up and you can earn 5% on all parts and services with the card. Hope this helps.
Old Sep 11, 2010 | 03:14 PM
818F150's Avatar
Yea you need a line disconnect tool, which looks like an "X" and you want to pick up the one that has 3/8 and 5/16 ends. And then obviously get the correct motorcraft filter. Then u slide underneath the car, by driver side (about 1- 1/5 foot in).
Heres the tricky part!!! ITS VERY FRAGILE!!!! Holding the line should be a blue "butterfly" clip. This forum will talk about it
https://www.f150online.com/forums/ar...el-filter.html
