Camber Kit
Old Jan 15, 2010 | 01:08 PM
W.L.B's Avatar
Camber Kit
I think I need a new camber kit. They said mine are cranked as far as they will go, and they start bending if they crank any harder. I have a procomp stage 1 6" lift. Does anyone have a reccomended camber kit and somewhere to get it. Preferably a link.
Old Jan 16, 2010 | 01:13 AM
W.L.B's Avatar
anyone?
Old Jan 16, 2010 | 01:35 AM
Paralyzer's Avatar
if you run out of room that is it...a new camber kit will yeild the same results. a camber kit can only adjust as far as the slots in the crossmember. This is a common problem with pro-comps they dont alighn worth a crap...camber is almost impossible to get into spec.
Old Jan 16, 2010 | 01:45 AM
W.L.B's Avatar
Originally Posted by Paralyzer
if you run out of room that is it...a new camber kit will yeild the same results. a camber kit can only adjust as far as the oem slots. This is a common problem with pro-comps they dont alighn worth a crap...camber is almost impossible to get into spec.
Well then WTF am I supposed to do?
Old Jan 16, 2010 | 02:16 AM
Paralyzer's Avatar
Rotate your tires often, thats pretty much all you can do...your not the only one on this site with this problem.
