Maintenance
Old Jan 13, 2010 | 02:39 PM
jalichoacan's Avatar
Maintenance
im about to go from alabama to california, and im running low on fluids. i will be changing the motor oil but im concerned with the power system fluid and brake fluid. should i go to ford and get them there? also, what kind do i need? and as far as the coolant, the motocraft gold stuff, do i need that or should i just put in some distaled water?
thanks
Old Jan 13, 2010 | 03:39 PM
AMMO_101's Avatar
Just top them off with dot 3 brake fluid. I reccomend getting some 50/50 anti-freeze and topping your system off. Have a safe trip
Old Jan 13, 2010 | 05:17 PM
mmelton005's Avatar
that or just drive through the you local grease monkey or jiffy lube something like that and have them do that with an oil change it's like 30 bucks here
Old Jan 13, 2010 | 05:34 PM
Need4racin's Avatar
Your question is kinda general...
Anyway coolant needs changed every 5yrs/100k miles. Yes motorcraft gold, or zerex g-05, mixed to a 50/50. ATF needs done every 30k miles. Gear oil, synthetic, every 100k miles. They say to change the t-case atf every 100k (or was it 150k miles?)miles. Only takes two quarts of mercon V.
To change the brake fluid you have to drain the system and rebleed it. I'd just wait till a caliper, something major needs replaced. What color is the fluid? It's a brown/tan color fresh out of the bottle.
Powersteering fluid doesn't ever get changed unless you have to drain the system. Takes Mercon (or Mercon V) atf.
edit- brake fluid or powersteering shouldn't get low.
Old Jan 14, 2010 | 10:53 AM
so for brake fluid.. just top off with dot 3
ill top off the coolant with motocraft gold
and what fluid do i need for power steering?
Old Jan 14, 2010 | 12:29 PM
vtelvr's Avatar
Not 100% true. As your brake pads wear, you will notice a slight decrease in your brake fluid reservoir.
Old Jan 14, 2010 | 12:48 PM
Harper 184's Avatar
Do not use anything beside the motorcraft gold on the coolant and do not mix coolant types, it gum up your radator.
