Anyone with a Headache rack?
Old Jan 15, 2010 | 09:21 AM
ZSK's Avatar
ZSK
Originally Posted by intoashes83
ZSK, the mounting is from the stake holes closest to the cab. there are bolts that bolt to the inside of the stakehole(if u have a bedliner it needs to be temporarily removed) and stick out the top. the adapters then are bolted to the top of the bolts from the stake hole, and the rack is slid between the 2 adapters and bolted through them. it is quite simple to install. took me 30min total to do.
Hmm, I'll have to think of a different mounting setup then, especially if I want to maintain the use of my tonneau. I don't think I even have stake holes with the crew cab.
Old Jan 15, 2010 | 03:36 PM
intoashes83's Avatar
there really is no difference between the pro and backrack. they are relatively the same exact thing. both racks can be had for less than 400 dollars shipped from various vendors online. Just remember if you order one, and think you may get a toolbox later on, order the rack with the mounting brackets for a toolbox. if you dont the first time they are roughly 65 to 75 dollars if you order them later.
im not sure how your going to maintain the tonneu cover with the backrack. even without the toolbox brackets the nonbox brackets still come out about 1.5" from the rack itself. As far as the mounting on the crew cabs go there has to be a mounting system. i have seen them mounted on trucks with crew cabs. when you order you just need to specify the cab type ie: crew, extended, standard. I am sure there is an application for your truck.
Old Jan 18, 2010 | 10:36 AM
I Eat Hybrids's Avatar
Sorry it took so long to post the pics. I just got rid of my F150 and bought my new truck a day ago and have been changin fluids, etc on it. So here are the pics of the mountin to the bed
Passenger side:
Driver side:
Another drivers side:
Let me know what yall think. If your interested just PM me
Old Jun 21, 2010 | 03:53 PM
misgur's Avatar
I've got a roll up tonneau cover from Laredo. Wonder if this rack will fit without getting the cover adapter. I think after putting the cover adapter on, it lifts the whole rack up a few inches and it just looks off to me.
Old Jun 21, 2010 | 09:03 PM
GTRider245's Avatar
The only question I have is, why would you want a headache rack with a tonneau?
