Alignment Questions
Old Dec 28, 2009 | 01:57 PM
W.L.B's Avatar
Alignment Questions
On my old tires the alignment was supposidly perfect but the inside of the tires still wore. They wore the same amount on both front tires. I had it realigned when I got my new tires but I am still worried. When they alligned it they set it to where the tires both tilt out a little more than what the machine says to. They said this is because of the over sized tires. Basically what I am getting at is there a special way to align a 2004 F150 with a 6" stage one procomp lift with 35" tires and 20" rims. I dont want these tires to wear unevenly like the last set.
Old Dec 28, 2009 | 02:53 PM
mdhawkin's Avatar
I think some of it could be caused by front end components going bad. What is the condition of your hubs and ball joints.
Old Dec 28, 2009 | 03:30 PM
W.L.B's Avatar
Ummm...I dunno
The truck has 99500 miles on it. The lift was put on at 65,000.
most cars are set with a little toe in, and once you are driving down the road the tires spread out a little, so i bet they just set toe to 0 instead of a few hundredths in like specs
Old Dec 28, 2009 | 03:31 PM
W.L.B's Avatar
They actually set it to -1 on both sides.
-1 or -.01?
Old Dec 28, 2009 | 03:49 PM
W.L.B's Avatar
-1 or -.01?
I think it was -1. Because it was in the green at -.9, but at -1 it jumped into the red.
Old Dec 28, 2009 | 04:18 PM
post up all the specs, and what the truck is at now. Did they give you a print out?
Old Dec 28, 2009 | 04:19 PM
W.L.B's Avatar
Yeah ive got the print out, I will upload them when i get home.
