ignition help!!
ignition help!!
I have a 2007 Ford F150, and Iam having problems,..when I turn the truck on in the morning or when ever is sitting there for a while,..my truck tends to backfire,..the RPM's would go up and down,..and when I accelerate so that it would stop doing that, smoke comes out of my tailpipe and smells like gasoline,..but onces it warms up no misfire or smoke, could anyone help me out I am getting tired of this!! oo by the way truck has 22,000 miles its has a saleen supercharger and has some new brisk spark plugs,.also had GMS coils but changed them to stock coils since I notice with stock coils it would do this problem less. Also when driving around and I go open throttle and then let go I can here my truck like backfire and it seems I have lost alot of HP,..I would appreciate if some can help,..thanks!!
i went and checked my truck today since it started throwing smoke.... i
opened the hood and oil everywhere... it threw oil where the head sensors
are located ...my check engine light came on so they check the codes
and i had a miss fire.... i had a (1)burned egnition,(2)sensors burned and (4)
spark plugs burned and my head gasket was also messed up and for some
reason there was water in my oil and inside my heads...... so that was my problem.... mite want to check your
truck also carlos before it gets worse like my truck... it mite also just be the cold weather down here.
