Key
Old Dec 24, 2009 | 09:54 PM
mauliemal's Avatar
Key
i have a problem with my key (not a copy). i dont have the keyless entry either, but ive noticed over the last month, when i try and open the door, it wont turn and i had to kinda play with it, is this normal on a 07 stx? i just dont wanna break it off in there
Old Dec 25, 2009 | 07:16 AM
shotgunz's Avatar
Try putting WD-40 or graphite in the lock (key hole).
Old Dec 25, 2009 | 08:51 AM
HCBPH's Avatar
Key
Does the other key do the same thing in that lock? How about the other door or the iginition? I have had that in the past on one vehicle, in that case it was a key that was 'slightly' miscut of one side. Flip the key over and it worked fine.
Myself, I'd put some graphite into the lock and see how it works. Over time I'm betting it's the lock itself so plan on having it replaced.
Old Dec 25, 2009 | 02:07 PM
robes74's Avatar
Whatever you do, do not use WD-40, it holds dirt and dust, find either graphite powder or white lithium grease to squirt into the hole. your best bet is to go to a locksmith and ask them to fix itfor you. Probably cost 3-40 dollars.
