Key Pad replacement
Old Dec 24, 2009 | 11:40 AM
Squiffo's Avatar
Key Pad replacement
Had the truck in at the dealer for service (had the 100K done at 95K - expensive!) and had them look at my key pad, which has been acting up a little.
When I punch in the code sometimes it works but sometimes it doesn't, when I punch in the code again it opens on the 4th digit.
I asked them about this and their respnse was I needed a new key pad (of course). I did a search but couldn't find if this is common and the only option is to replace the unit (I was quoted ~$300 all up to replace).
Any advice/ tips always appreciated!
Chris
Old Dec 24, 2009 | 11:43 AM
Chris
Order one from Tasca and replace it yourself. I had never done one and installed mine in about an hour.
Old Dec 24, 2009 | 12:01 PM
Squiffo's Avatar
Couldn't find it on Tasca using their search. Do you have a part # or link?
Old Dec 24, 2009 | 12:12 PM
Here is a number from an older post. May still be the same. I can check when I get home.
https://www.f150online.com/forums/2039138-post14.html
Old Dec 24, 2009 | 12:28 PM
Looks as if the part number is superceded by this one, and they do not have it. I bought mine at the local Ford parts department.
8L3Z1522405AA
Old Dec 27, 2009 | 12:18 AM
arogers's Avatar
Just curious - how much was the 100K service?
Old Dec 27, 2009 | 02:30 AM
Squiffo's Avatar
$816 although I had some extra stuff done while in. I had a complete tranny service done, which I've done almost every 10K since I tow so much.
At the suggestion of one of my customers, who works at the parts dept for a Ford dealer, I'm going to order the replacement door handle with keypad ($70) and have a body shop put it in. I heard it was a PITA so will have someone else install it!
Old Dec 30, 2009 | 02:58 PM
Greystealth's Avatar
I just replaced my handle which came with a new keypad included. Cost me 97 just for the handle at ford. Was a bit of a pain to install but if your technically savy, you should be able to figure it out.
Old Dec 30, 2009 | 03:06 PM
It really is not that hard to do. There are instructions on here you can follow. Took me about 2 hours.
Old Dec 30, 2009 | 08:54 PM
Squiffo's Avatar
Part + tax and shipping was about $90. Body shop will install for $50 so about $140 and I can work for two hours instead, which will pay for it.
The body shop is also taking care of a ding in my right rear quarter panel. Looks like a bike hit it but can't tell for sure - damn hit and run's!
