how do I clear "check gascap" message?
I lost my gas cap yesterday, and my odometer no says "check gascap". I replaced it but the message didn't go away. How do I clear this? Do i have to disconnect my battery? thanks
1. It will go away once the OBD-II cycle successfully completes a pressure decay test without a leak.
2. Get a tuner and clear it yourself.
3. Go to an Autozone and have them clear it for you.
All of the above assumes that you replaced the cap with a good OEM type that is sealing properly - just give it a couple days or go to Autozone as others mentioned (Autozone will check codes for free, and the checking process clears the codes).
