help with which rearend i have
ok hear is the deal i had an axle seal leak on my 2004 f150 ex cab 4.6 auto. from what i could make out on the tag it says its an 8.8 rearend. the cover also has 10 bolts. the problem is when i went to the parts stores 2 differant ones the seals that fit the rearend are for a 9.75? even looking online it does take 9.75 seals. i am just wondering which rear it is because after i tore it down it also needs spider gears
all this at 60k.
just want to make sure i get the right spiders the first time.thanks
all this at 60k.
