Fixing 12 volt power supply
My front 12 volt power supply quit working the other day, but the cig lighter and rear 12 volt are still working. Do I have to take the dash apart or is there another way to fix them?
It has its own fuse that is separate from the cig lighter and rear power point. Its a 20A fuse #39. I bet that's your problem.
Last edited by mdhawkin; Nov 17, 2009 at 07:34 PM. Reason: I posted fuse number for an 08 not an 04, the correct number is listed now.
Is anything else dead? Have you (or anyone else) messed with the wiring in any way (added any aftermarket stuff?) I'm pretty sure the cig. lighter fuse also powers the OBDII port under the dash. That and the power point should both be 20A fuses. Are those the mini fuses that you replaced? Take a test light (or DVM) and see if you have juice coming to the fuses. Should be 39 & 41.
According to the manual its fuses 110 and 117 and they're cartridge fuses. Theres power in the fusebox but none getting to the ports. There is a line level converter in the dash. I'll have to pull it apart and have a closer look.
Thanks!
I have an F150 2006 flareside and My dash 12 volt was inop, so I pulled the #39 20 amp and yes it was blown at first I thouhgt 8it was ok till I put a light on it then I could see a 1/16th gap, any ways i replaced it and its working fine.
