05 King Ranch Instrument Cluster Question
Old Nov 16, 2009 | 11:50 PM
wolfpack's Avatar
I recently got an 05 F150 King Ranch 4X4. On the instrument cluster (were the gears would be written if the shifter was on the column) it says lariat instead of king ranch. I know i have seen several other 150's that said king ranch there(im not sure if they were 05's, they could have been 06 or 07), and i was wondering why mine says lariat? And also i wanted to know if there is a way to get it to say king ranch other than just replacing the entire cluster?
Thanks for the help
Old Nov 24, 2009 | 07:01 PM
nascar99ford's Avatar
Chances are that the cluster has been changed out with one from a Lariat. I swapped a standard column-shift cluster with a FX4 floor-shift cluster. To remove the "FX4" where the PRND21 should go, I just pushed in the two snaps that hold in the plastic piece and pulled it out. If you can find one that says "King Ranch" (if this body style has it) you can just swap it out.
Hope this helps
-Matt
