2008 22" limited wheels on an '08 crew lariat?
Old Nov 10, 2009 | 10:14 PM
drj02's Avatar
Can anyone tell me if a set of 2008 22" factory limited wheels will work on my 2008 F150 Supercrew Lariat? Any concerns to be aware of if I do? Thanks for everyones time on this one.
Old Nov 10, 2009 | 10:19 PM
05RedFX4's Avatar
They will fit just fine. The limited wheel is the same casting as the 06-07 harley wheel, they are just painted white. There are several members who have the 06-07 harley wheel on lariats, FX4's, XLT's, STX's, etc and they fit.
Old Nov 10, 2009 | 10:26 PM
drj02's Avatar
Thanks so much! How do I calibrate the 22's as I have the factory chrome 18's on right now. Are there any tire pressure sensors or tire rubbing I need to worry about since I have the Lariat verses the Limited model?
Old Nov 10, 2009 | 11:00 PM
87fiveoh254's Avatar
You'll need new tire sensor bands to attach the stock sensors to the bigger wheels. You shouldn't have any rubbing issues if you're at stock height.
Old Nov 11, 2009 | 06:31 AM
drj02's Avatar
Thanks for the heads up. Any idea of cost and / or where to purchase the tire sensor bands by chance?
Old Nov 11, 2009 | 07:07 AM
05RedFX4's Avatar
If they are actual limited wheels from 08, they should still have they factory bands still there. Just clip your sensors onto the new wheels and mount some tires. OEM size was 275-45-22.
BTW the limited is a lariat loaded to the max. It was actually a special option package on the lariats just like the harleys and the king ranch.
