Big Rig/Train horn issue
Old Nov 8, 2009 | 04:59 PM
knighj1's Avatar
Question Big Rig/Train horn issue
Ever since i hooked up my big rig kit, I =have had this issue and am wondering how I can fix it.
I have a 275c with a 2.5 gallong tank and a set of horns, it is wired to my truck horn switch
If I tap the horn it sounds great, but if I lay on the horn it drops the sound of the horn as like it is hoarse. I checked my tank and pressure gauge while my wife blew the horn and its not running out of air, it starts at like 140-145 and sounds horrible if held down.
How can I fix this?
Old Nov 8, 2009 | 05:05 PM
knighj1's Avatar
This is my kit
http://www.assuredautomotiveproducts...IR275c-25G.htm
Old Nov 8, 2009 | 06:04 PM
06yz250f's Avatar
how big of hose?
PM coobies, hes pretty good with train horns.
you go to auburn?
Old Nov 8, 2009 | 06:30 PM
gcart's Avatar
wouldnt that just be because you are out of air in the tank?
Old Nov 8, 2009 | 06:36 PM
coobies5's Avatar
lol.....duh
you lose air when you honk the horn......and thats why you have a compressor......it fills the tank back up.
imagine blowing through a straw...of course when you start its going to come out hard and fast....but after a few seconds its going to get weaker and weaker until you take another breath.
Old Nov 8, 2009 | 07:09 PM
gcart's Avatar
I thought that sounded right, i didnt know if i misread the question. just get a ten gallon tank and you will be able to hold it for a couple seconds.
Old Nov 8, 2009 | 08:08 PM
coobies5's Avatar
10 gallon on 140psi down to whatever his pressure switch is at. and im guessin 1/4" hose....he could hold that down for a good while....like 20-35 seconds.
Old Nov 8, 2009 | 09:06 PM
knighj1's Avatar
1/4 line, it just sounds like it boggs down and its not out of air the gauge is still reading 135+,
It can be full at 150 psi and if I hold the horn down it sounds good for maybe a second then sounds like crap, maybe I do need a bigger tank, but I would think I could hold it down for 5-8 seconds before running out of air
Old Nov 8, 2009 | 09:07 PM
knighj1's Avatar
does it matter how far the tank/compressor are from the horn? I have the horns in the front and comp/tank in the tool box.
Old Nov 8, 2009 | 09:10 PM
gcart's Avatar
thats a lot of air moving. 2.5 gallons is nothing.
Old Nov 8, 2009 | 09:11 PM
bankrpt's Avatar
yeah that tank isnt big enough those horn will suck the air real quick i have a set on my show truck with a ten gallon tank but im using nitrogen instead of compressors cause i use the nitrogen for my air ride i have my regulator set a 350psi and thats how much psi im running for the horns also its loud as He$$
Old Nov 8, 2009 | 09:52 PM
IORf150's Avatar
I think I know what your talking about, I was having the same problem with my old horns. It honks at first, then it starts making a screaching noice, my problem was my air valve, it wasn't opening all the way up, and that was with a 5 gallon tank and it would start screaching after a couple seconds.
Old Nov 8, 2009 | 09:59 PM
knighj1's Avatar
Finally someone knows what Im talking about, what did you do to fix it, I ruined my horn by experimeenting so I have to order a new horn tomorrow
Old Nov 8, 2009 | 10:21 PM
freekyFX4's Avatar
I have a 20 gallon tank, and I can blow my horn for almost 20 seconds. If I had a 2.5 gallon tank, it would only be about 2 seconds. Get it? It's also possible that you need a better solenoid valve. Some of them are really cheap. A good one will run you $50 or more.
Old Nov 8, 2009 | 10:30 PM
knighj1's Avatar
I ordered a new horn with new valve if that does not work, Im going to order a better set of horns with a better solenoid
