Sensonr on the vertical radiator support
Old Oct 31, 2009 | 11:34 PM
mep32jep's Avatar
Can someone tell me what the senson or platic piece is that is located on the vertical radiator support. It is a couple of inches down from the top and appears to be a sensor of some kind. Thanks
Old Oct 31, 2009 | 11:49 PM
bjp207's Avatar
Airbag crash sensor
Old Nov 1, 2009 | 12:02 AM
City of Champs's Avatar
Its the ambient air temp sensor.
Old Nov 1, 2009 | 12:27 AM
mep32jep's Avatar
OK, now I am confused????
Old Nov 1, 2009 | 12:45 AM
fatty4x4's Avatar
it is the air temp sensor.
Old Nov 1, 2009 | 02:07 AM
code58's Avatar
I know for a fact the air bag crash sensor is mounted in the vertical support. I don't remember right now if the temp sensor is also (to late to go out and look right now), but it could be, so both answers might be right. The A/B sensor is mounted lower down on the vertical support, not that close to the top.
Old Nov 1, 2009 | 01:43 PM
mep32jep's Avatar
Thank you all for your help
Old Nov 1, 2009 | 01:44 PM
cstanek's Avatar
The one on the top is the outside thermometer. The one on the bottom (mine has a barcode on it) is the airbag crash sensor.
Old Nov 1, 2009 | 10:15 PM
bigblackford's Avatar
Haven't looked at mine lately. But, the airbag wiring is usually decent sized wiring and is usually yellow or yellow with a stripe. It's the only wiring in the vehicle that is this color so it is easily identified so you know to stay away from it.
Old Nov 2, 2009 | 01:26 AM
fatty4x4's Avatar
Well said
