Auto Headlight Problem!
Old Oct 28, 2009 | 01:28 AM
Projekt54's Avatar
I tested the sensor with a flashlight. The lights come on and off, fog lights, and parking lights but no head lights. any help would be appriciated. also everything works fine doing it manually
Old Oct 28, 2009 | 03:13 AM
Impact9's Avatar
Got me there. I'm at work with nothing going on and been looking at the wire diagrams on alldatadiy.com for a good hour now and can't understand this problem. What model year is your truck?
Only guess I have is maybe your headlight switch is messed up but that's a long shot.
Old Oct 28, 2009 | 06:49 AM
hedgehogforprez's Avatar
Mine is doing it as well, I thought it could be a fuse blown somewhere but maybe I'm wrong?
Old Oct 28, 2009 | 11:30 AM
Projekt54's Avatar
Its an 05 FX4. Yea, kinda weird. headlights are good, and the sensor goes on and off with light and dark, just headlight wont come on. they work if i do it manually.
Old Oct 31, 2009 | 01:17 AM
Projekt54's Avatar
No ideas! I guess i could go buy a new headlight switch see if its the problem or now...
Old Oct 31, 2009 | 03:56 AM
Impact9's Avatar
From what I was looking at the switch is hard wired to let everything turn on when the sensor is active. The sensor is basically a simple switch that lets power flow to the lights through the headlight switch.
You might suspect the body control module but from what I can tell you would have no light if it malfunctioned.
Maybe someone with a actual factory manual can clue us in if something is missing from these diagrams:
Old Oct 31, 2009 | 08:48 AM
05FX4SCREW's Avatar
Have the same problem with mine. I took it in to Ford right before my extended warranty expired and they told me it was something like the security module part of the body control module and not covered. I told them for the $400 it was going to cost to fix, I can turn the **** old-school style to get the headlights to come on.
Old Dec 19, 2009 | 06:11 PM
rodhofeling's Avatar
Same problem
I am having the exact same issue. Has anyone figured this out?
Old Dec 19, 2009 | 07:29 PM
W.L.B's Avatar
Its not part of the auto lamp fuses or relay is it?
Old Dec 19, 2009 | 11:12 PM
bjp207's Avatar
I'd say its probly the relay
Old Dec 21, 2009 | 08:59 AM
Projekt54's Avatar
Well i went up north and flashed my used my highbeams a couple times, came home and now they work again. Its stranged, they work fine once in a while they wont but they work most of the time now i give up lol!
Old Jan 14, 2010 | 10:17 PM
jimc2004's Avatar
I am having the same problem with my 2004. If anyone has a solution, please let us know. I kinda want to try a new switch, but don't want to lose out if it is not the problem.
Old Jul 20, 2012 | 04:38 PM
pciscott's Avatar
I have had the same problem with my 05 Ford F150 Supercrew and been cruising the forums. I figured the problem why my Parking lights worked but my headlights did not work on auto only if I turned on the switch.
After replacing the factory switch isolated the problem to the Body Control Module (BCM) behind the rear seat on the driver side.
The hardest part of the repair was getting the rear seat out, but here is some help from another member http://i222.photobucket.com/albums/dd14 ... 1232255578
When I unplugged the module I noticed the corner pin on the Blue plug looked like it was hot and the plug was melted and the pin was burnt black. I took the module out and opened and ran a 16 gauge wire to the inside of the burnt pin and soldered it on contact. I then drilled a small hole to run the wire through. I cut the red/yellow stripe wire from the coresponding pin on the outside plug and butt spliced the two wires together taking the bad pin and socket out of the equasion. In my opinion too much current on a small contact.
Good news is my auto headlights are working again after being out for over a year. The problem was not the BCM but a bad connection going to the BCM.
Tools needed so you have everything
small screwdriver to remove middle seat belt cover shoulder plate
10mm socket to remove two nuts
T50 Torx to remove shoulder belt
Medium size straight edge screwdriver to push in seat clips to remove rear seat, this job is tough but the latches are above the child seat tethers on the bar that holds in the seat. They are almost even with the outside tethers, but a few inches above. Check out diagram above for help.
you will need a 8mm to take the two bolts holding the BCM in.
two small screwdrivers to pull the board out of the BCM case.
Sorry I did not take pictures, but I know how frustrating it is to have things not work on your car and I hope this helps.
First time post so sorry if I dug up and old thread
I did the whole job in less than an hour, but i had all the tools and solder equipment.
