Old Oct 26, 2009 | 04:23 PM
gcart's Avatar
275/60/20
anybody have that size tire and wheels.
the size is 33/10.83/20 and it is like 140 bucks cheaper a tire compared to a 33-12-20.
i was thinking a cooper zeon ltz in that size with xd hoss.
Product Name: Hoss 20x9 6/135
Description: XD Hoss one-piece chrome plated aluminum custom wheels with -12mm Offset, and 4.5" Backspace for lifted trucks. Free Shipping
on my 2wd with a 2.5" leveling kit.
Old Oct 26, 2009 | 06:15 PM
Windsor's Avatar
I've been contemplating that size. Personally, I think that rim has too much offset. Your stock wheels are +44mm offset. You're moving the center of the rim almost 2" outboard. The only reason I can see moving the tire outboard is to gain clearance from the upper control arm. 275"s came standard on my truck, so clearance is not an issue with the stock or near stock offset, even with a lift.
If you like your tires sticking out from under the wheel well, or contemplating big wheel flares, then this will do it for you. If you want the tire tucked under the wheel well, you should find something in the +30mm to +44mm range.
Old Oct 26, 2009 | 10:26 PM
dirk upson's Avatar
i have that size of tires on my truck, but they are on the factory 20s. no issues wiyh rubbing.
Old Oct 27, 2009 | 06:21 AM
gcart's Avatar
I am going for the wider stance, but couldnt see myself dropping another 500 bucks for a 1" wider tires.
Old Nov 19, 2009 | 05:34 PM
Xterrable's Avatar
Thats the tire size I have at stock height and stock 20's. Not to bad. I dont like wide tires IMO..
Old Nov 22, 2009 | 08:34 PM
benjamminh6's Avatar
ive got those on my truck! ive got aftermarket rims (KMC Hotwheels which i powdercoated black) i think that they look great on the truck...not too small, not too big!
Old Nov 23, 2009 | 08:56 AM
Big Slick's Avatar
how about some pics guys?
