air bag springs and brake proportioning valve
Old Oct 14, 2009 | 09:05 PM
TbaggsTruck's Avatar
In the manual for my new Air Lift ride controlers it says: "Your vehicle may be equipped with a rear brake proportioning valve. Any type of load assist suspension product could effect brake performance. We recommend that you check with your dealer before installing this type of product."
I am pretty sure my 04 5.4l fx4 has a proportioning valve, what should I do or watch out for?
Old Oct 15, 2009 | 04:07 PM
mkosu04's Avatar
I'm pretty sure the 2004s use the ABS to prevent rear wheel lockup instead of a load sensing prop valve.
but not positive... better check with a dealer...
Old Oct 15, 2009 | 11:25 PM
I think mine may be opposite than that. I have a brake hose that branches off the rear distribution block and is mounted above (proportioning valve?) and only have wires (to sensors) to the front hubs.
Old Oct 16, 2009 | 06:13 AM
PHS79's Avatar
I understand what they are talking about, but I think they just put that in the manual just to cover their a--. I have Firestone Ride-Rite bags under my truck and I have never noticed any issues that would require messing around with the proportioning valve, and I have had mine loaded VERY heavy (6000lbs once and over 3500 lbs a 6-7 times). I wouldn't worry about anything at all, just put the system in and use/enjoy it.
Old Oct 16, 2009 | 09:55 AM
Good to know, thanks.
BTW, great looking truck, any rubbing issues with those tires? How do they do in the snow?
Old Oct 16, 2009 | 01:10 PM
PHS79's Avatar
Thanks man!! They only have rubbed 5-6 times in the 3+ years that I have had them on. I have only had them in the snow once, I always put the stock wheels/tires back on for winter.
