Lights
Old Oct 13, 2009 | 10:50 AM
ryanralston07's Avatar
Lights
I'm looking for 4 fog lights and want 2 smaller ones on the outside and 2 larger ones in the middle of a light bar. I'd like the outter 2 to be able to act as driving lights and the middle 2 to be almost spot lights. I'm thinking two 5" lights on the outside and two 6" or 7" lights on the inside. Any opinions on that setup? I have no clue which lights to go with, but I'd like to have the outter 2 tied in to my light controls that came stock and the other 2 to be on a switch. Which lights should I look at?
Old Oct 13, 2009 | 11:01 AM
mdhawkin's Avatar
So many options, I think the best place to start is determining your budget. There are several good manufactures out there but their product range is vast and extends beyond decisions other than size. Hella, PIAA, KC, etc.
Old Oct 13, 2009 | 11:05 AM
NCSU_05_FX4's Avatar
I agree with mdhawkin, how much are you willing to spend?
I like my PIAA 525s Driving/Fog lights, but they're not cheap. What type of light bar will you be mounting them on?
- NCSU
Old Oct 13, 2009 | 11:27 AM
thejake1989's Avatar
i went cheap with my first set and used them as spots and they work great (cept one stopped working and i havent looked into fixing it yet). but i just ordered some hella's that i can us as driving lights and one ill have as a spot.
Old Oct 13, 2009 | 11:35 AM
I'm looking to spend roughly $4-500 on lights (for all 4) and looking at a smittybilt light bar I found for $109 on ebay new.
Old Oct 13, 2009 | 12:13 PM
mdhawkin's Avatar
PIAA has several different lights that would fit your project. One combo that might be close to what you are looking for would be:
PIAA 580 series (pencil beam 5 degrees, xtreme white, 6 11/16 tall) - $290.00
PIAA 510 series (driving beam 30 degrees, xtreme white, 3 15/15 tall) - 219.00
This puts you a couple bucks over budget and the two lights have slightly different covers. In order to get the size difference you want between the two it makes staying under budget a little hard to do.
Old Oct 13, 2009 | 01:17 PM
dilloncawthon's Avatar
i agree you should go with the setup above or something similar but if you do here are the 510's for a pretty low price. that's where i just ordered mine from should be here wednesday.
the piaa 510's for about $165
http://stores.got-chrome.com/Items/P275164
Old Oct 13, 2009 | 01:30 PM
mdhawkin's Avatar
I did not do price checking when I put the above together for you. I am sure you can find them cheaper, I believe those are retail prices for the kits.
Old Oct 13, 2009 | 02:28 PM
I'm looking at KC Hilite Daylighter 6" 130w Spot Lights for the middle 2 I want to be the strong ones, and now I'm trying to find some smaller KC's that would be fogs or driving lights...
Old Oct 13, 2009 | 10:59 PM
Impact9's Avatar
Fogs get the piaa 520 crystal ion fogs and mount them low as possible. Look at my sig they are the bottom lights. They work fantastic in fog with a really good cut off.
Old Oct 13, 2009 | 11:04 PM
so should I get the KC's with those PIAA's or should I not mix-match?
Old Oct 14, 2009 | 02:27 AM
yeah your prices are pretty much right for most places. i neat trick i've found is to type in whatever you are looking for on google shopping then set the search to prices lowest to highest and you can find some really good deals.
Old Oct 14, 2009 | 08:44 AM
What size fogs we have on our trucks factory? (2008 year lariat)
Old Oct 14, 2009 | 10:52 AM
Impact9's Avatar
Ryan I would get a pair of PIAA 520's switched independently from a set of KC's. KC Daylighter series is time tested and tough as nails and I love mine. The PIAA's are really though also. Here's a photo of back when i had a standard brush guard on. The key is to get the fogs as low to the ground as possible because you want them to illuminate the road under the fog and not the fog itself. That's function, if you just want something for show then I think Pro Comp makes some good looking offroad lights. Prices are pretty good here at 4wheelparts.com
IMO 8" lights tend to be a bit too much even when I considered them on my truck. Unless it's a true offroad baja truck I'd skip the 8's.
Old Oct 14, 2009 | 12:46 PM
they are somewhere around 4-4.5in.s
