50,000 Mile Maintenance?
I've received a couple e-mails from the dealership regarding a 50k maintenance that needs to be done. Honestly, I've never had a vehicle with this low miles so I'm not sure what may or may not need to be serviced yet. Is there a list anywhere? The gentleman from whom I purchased the truck took amazing care of it so it's not abused (and I haven't thrashed it either in the four months and five thousand miles since I bought it.)
I'm sorry if it's very obviously posted somewhere and I just didn't see it, but I'd like to see what's on the "list" so I can whether I actually need to bring it in or if it's mostly stuff I can do.
Thanks, guys!
Thanks, guys!
On mine I also changed the brake fluid and coolant. Although the coolant us "supposed" to be good for 100K, it does weaken over time. Always refill with the original ford gold coolant. The brake fluid almost always will get moisture in it over time. Both can be tested with test strips kinda like litmus paper.
Works when I click on it. Maybe because I was logged into the site I got it from?...https://myford.fordvehicles.com/serv.../Page/HomePage.
Try www.motorcraftservice.com then look up owners guides. Select your year, model and the particular document you want to look at.
You can get them from genuineservice.com too. Under "Glovebox" at the top, select Maintenance Schedule and enter your vehicle details. Same thing, just a different way to get it.
