power rear slider help
Old Sep 22, 2009 | 12:42 PM
olson99's Avatar
I recently purchased a 2005 ford f150 supercrew that has the power rear slider and it doesn't seem to work I haven't really got a chance to work on it but wondering if there is a common problem I need to know about that might get me started in the right direction
Old Sep 22, 2009 | 01:06 PM
yetti96's Avatar
Just keep pressing the switch and lightly grease the cable/track. Pretty common problem is not used often enough.
Old Sep 22, 2009 | 03:25 PM
olson99's Avatar
thanks I will try that
Old Sep 22, 2009 | 09:49 PM
Jughed's Avatar
I just bought mine and same problem. I tried the working it while holding the button and had no luck. Luckily I hadnt paid for the truck yet and told the dealer I wanted a new regulator/motor in case I couldnt get it working. They said OK and threw in a new set of motorcraft shoes for each corner. BTW any one need some motor craft shoes for their rig? Im not putting these dusty things on here.
Good Luck, but I read on here if you do get it working use some silicone lube and a lot of members open it every day to keep it from sticking again.
Old Sep 22, 2009 | 10:30 PM
XL1200Ltd-Keith's Avatar
This worked for me.
http://www.ford-trucks.com/forums/86...-easy-way.html
Old Sep 22, 2009 | 11:25 PM
greencrew's Avatar
Thanks for the pointers. I'll have to keep mine lubed. Any suggestions on which lube to use?
Old Sep 23, 2009 | 09:08 AM
Drunkonjack's Avatar
Originally Posted by XL1200Ltd-Keith
I just tried this and it worked . That saved me a few bucks.
Old Sep 23, 2009 | 10:57 AM
Jughed's Avatar
THANKS, I love hammers. Works like a charm! I put some silicone lube in th etrack and the cables. Worked it back and forth a ew times and nice a nd smooth. Saved me a lot of work and I have aback up motor also.
Old Oct 4, 2009 | 07:43 PM
4 da boat's Avatar
thanks Keith
mine was not working for a year. It did not work with a small hammer so I got a bigger one and it works fine now.
