Window Regulator
Window Regulator
Well sunday my passenger window regulator went "pop" and dropped, you all know how that happens
i took it out to check it and the wire was out of the plastic roller. My question is if there is any way i can roll it and get to work or do i need a new regulator?
That appears correct to me, for just the regulator. You will have to add your old motor to it. I replaced my regulator and motor as a new unit.
my motor is good, so i just need the regulator.. ima go ahead and order it.. ima trust you lol
Good luck!
Every time you order something, you take a chance! Replacing that regulator is taking a chance! So, yep, good luck!
