Auto dimming side view mirror
Old Sep 16, 2009 | 04:24 PM
Brandon Miller's Avatar
Just curious as to how many other people have a driver side auto dimming mirror on their F150. My '07 FX2 has it.
Old Sep 16, 2009 | 04:37 PM
grassmanfx4's Avatar
I didnt even know that was an option. Cool.
Old Sep 16, 2009 | 04:39 PM
mixedbreed's Avatar
08 larry check
Old Sep 16, 2009 | 06:00 PM
labman1014's Avatar
my 08 lariat had it, but i switched to the TT mirrrors so i no longer have it...
Old Sep 16, 2009 | 06:24 PM
mbarbera's Avatar
Got it on my 08 lariat. Does any body elses shake when driving down the road. I already had it replaced once.
Old Sep 16, 2009 | 06:33 PM
05RedFX4's Avatar
The auto dim feature is standard on power mirrors from 07-up and it's only on the drivers side. TT and manual mirrors don't get it.
Old Oct 15, 2009 | 01:32 PM
epolite1975's Avatar
Help
I can't find a self-dimming, power driver-side mirror anywhere. It's for an '07 V8 5.4L SOHC.
Can anyone help?
ETA: Even if you only know the part number, that would help a lot.
Old Oct 15, 2009 | 01:55 PM
HCBPH's Avatar
Mirror
Can anyone help?
Bought mine used so can't help on PN but my 07 XLT Scab has that and heated mirrors. It is nice when someone pulls up behind you. Might be model dependent?
Old Oct 15, 2009 | 02:06 PM
Fordfanatic101's Avatar
my 07 does not have that (power adjust only) at least i don't think it does
Old Oct 15, 2009 | 02:19 PM
05RedFX4's Avatar
I made my earlier post before I pulled my mirrors apart to paint my caps. When I pulled them apart I discovered the drivers side has 4 wires going to the glass, 2 for the heat and 2 for the auto dim. The passenger side only has two wires for heat. So maybe you have to have the power/heated mirrors to get the auto dim.
If you look closely at your mirror glass, there is a 1/4" wide border around the glass and the middle has a coating on it almost like a tint job on the mirror and it only darkens at night when someone lights are in your mirror. During the daytime its almost undetectable.
Old Oct 15, 2009 | 06:04 PM
saleen's Avatar
Is it possible to put on on an 04-06?
Old Oct 15, 2009 | 06:35 PM
05RedFX4's Avatar
Yes, but you probably will need the entire housing due to the extra wires for the auto dim feature. The mirror glass itself will physically snap into an 04-06 housing but the wires are not there for the auto dim. I would imagine you could run your own leads for the A.D. and save your self a ton of coin, because the glass only is 14 bucks from tasca.
http://www.trademotion.com/partlocat...=2&catalogid=2
Old Oct 15, 2009 | 07:10 PM
saleen's Avatar
Can you see the sensor? Is it in the mirror or does it tie into the rear view?
Old Oct 15, 2009 | 07:56 PM
05RedFX4's Avatar
That I don't know.
Old Oct 16, 2009 | 12:10 PM
I've never been able to locate the sensor. I don't think it's tied in to the rear view because when my rear view dims, the side view doesn't always dim, only when lights hit it directly.
