Flex a Lite Electric fan on 07Mark LT
Old Sep 16, 2009 | 10:55 AM
rgrpm's Avatar
Has anyone replaced the factory fan with an electric? I have a fan kit off my 04 F150 that will fit but not sure about the fan clutch on this truck being electric. What do I do with the fan clutch wiring on it now. What controls the clutch wiring? am I going to get check engine lights on if disconnected? Please help. Rod
Old Sep 16, 2009 | 08:36 PM
countyboy04's Avatar
There have been plenty of people around here to add electric fans. I havent done it yet so I dont have anything to offer.
Old Sep 16, 2009 | 08:44 PM
Windsor's Avatar
I have an '08 and installed e-fans. Just leave the fan clutch harness unplugged. There is no MIL light, but there's probably a code if you use a scan tool.
Old Sep 17, 2009 | 06:50 AM
rgrpm's Avatar
Thanks for the info
I unplugged the harness yesterday and drove around, no check engine light and seems to run fine, I am installing fans today.
Old Sep 17, 2009 | 07:14 AM
Windsor's Avatar
There is a parameter in the pcm that sends juice to the clutch when temps are just over 200 degrees to lock it up.
Old Sep 17, 2009 | 07:19 AM
mixedbreed's Avatar
Just do it. You splice into the factory harness on the firewall. Do you have instructions? What controlers are you using?
Old Sep 17, 2009 | 07:35 AM
05RedFX4's Avatar
Interesting.... couldn't you use that signal to feed a relay to turn your e-fans on and off thus eliminating the POS fan controller?
Old Sep 17, 2009 | 07:58 AM
mixedbreed's Avatar
In theory, thru a relay. But you lose the staggard turn on. Unless one is wired a/c only and the other coolant temp regulated.
Old Sep 17, 2009 | 08:22 AM
05RedFX4's Avatar
I was thinking of something similar, run two relays one for the coolant temp and one for the a/c and have each control a separate fan. Since there is only one temp stage, wire the temp controlled relay to also kick on the a/c relay (thru diodes to prevent backfeed) so when the a/c is on only one fan is running, but when the temp relay kicks in both fans run. You would also have a safety built in because if one fan failed you still have another fan to cool.
Old Sep 22, 2009 | 06:32 AM
rgrpm's Avatar
Update on Fan Install
You have to move the ABS back aprox 1 1/2" to clear the fans and other than that nothing to it. Have been driving for 3 days and the fuel mileage is reading out at 13 mpg. Before the fan install it was at 14.6, I I do not understand how that can be but like the guy earlier stated my mileage has Dropped after installing efans. Any ideas?? Thanks,Rod
Old Sep 22, 2009 | 03:22 PM
mixedbreed's Avatar
Mine did too but it leveled back to normal. Give it a little longer.
