Truck shuts off when I shift into park
Old Sep 16, 2009 | 07:01 AM
mengela's Avatar
I have 2004, 5.4, 4x4. Efans, 3.5" af1 intake, magnaflow sido, and custom troyer tunes for 87 performance. First it would shut off when I came to a stop or coasting down a hill, never under throttle. I then bumped the idle rpms to 650, its pretty much stopped shutting itself off other than when I shift into park... it will very consistently shut off. Besides bumping the rpms up again... does this sound like a more serious problem?
Old Sep 16, 2009 | 08:42 AM
Marc Carpenter's Avatar
I would suggest you call them and ask them if it is something that they are familiar with. I doubt if you will find the answer you seek here.
Old Sep 16, 2009 | 09:38 AM
ELVATO's Avatar
Did this happen right after one of your mods, or just randomly? Does it idle fine in D before and after the bump in RPMs?
Old Sep 17, 2009 | 10:48 AM
mengela's Avatar
yes it idels fine now and cruises fine but shuts off when i shift to park
Old Sep 17, 2009 | 11:32 AM
Impact9's Avatar
Sounds like a tree hugger got under your trucks.
I wonder if your fuel pressure is getting low. Might change the fuel filter and see if that helps.
Old Sep 17, 2009 | 11:56 AM
mengela's Avatar
no codes being thrown, fuel filter is 5k old, how could i check fuel pressure
Old Sep 17, 2009 | 01:40 PM
Arca_ex's Avatar
Did you try setting the tune back to stock...
