lights dim with off road lights on
Old Sep 15, 2009 | 07:37 PM
penguinasa's Avatar
My dash lights dim when I turn my off road lights on behind my grill. Is this normal?
Old Sep 15, 2009 | 07:41 PM
Watson91's Avatar
Em no? What kinda lights are they, and how did you wire them up?
Old Sep 15, 2009 | 07:45 PM
abervintageman4's Avatar
too much draw from the battery......
Old Sep 15, 2009 | 07:49 PM
Watson91's Avatar
I don't know how that could be he has two 130wats behind his grille i think. I have that hooked up to stock battery among other things and have no problems.
Old Sep 15, 2009 | 07:53 PM
it depends on the CCA on the battery too and what other electrical components he has hooked up that can cause a strain on the battery and alternator
Old Sep 15, 2009 | 08:09 PM
penguinasa's Avatar
they are two 55 watt **** cepek lights. I ran them to the breaker and battery then to the switch which branches to the running light wire. Does that sound right?
Old Sep 15, 2009 | 08:14 PM
i thougt most lights used a relays, email the company and ask for a wiring diagram
Old Sep 15, 2009 | 08:17 PM
penguinasa's Avatar
sorry, not breaker. It does have a relay
Old Sep 15, 2009 | 08:21 PM
okay good circuit breakers should never be used for cars haha, just ask for a wiring diagram and double check to make sure its wired up properly, but you are still creating a draw on the battery and alternator whenever you turn the lights on and thats more than likely going to be your cause
Old Sep 15, 2009 | 08:24 PM
penguinasa's Avatar
So it is not because I went to the running lights behind the switch?
Old Sep 15, 2009 | 09:02 PM
i highly doubt it, i had some 35w fogs for a while and they didnt dim at all but then again i have 0 guage wires to the grounds under my hood and chassis so that helps
Old Sep 15, 2009 | 10:07 PM
penguinasa's Avatar
I will increase the ground size and see what happens
thanks aber
Old Sep 15, 2009 | 10:21 PM
grassmanfx4's Avatar
My headlights and fogs went dim when i first wired mine up due to a bad ground.Turns out i didnt tighten one of the ground all the way.
Old Sep 15, 2009 | 10:57 PM
Watson91's Avatar
Sounds about right. My lights run to a relay mounted under my dash. Then the relay goes off to the switch and battery. I would check your ground and make sure it is good.
Old Sep 15, 2009 | 11:25 PM
GTRider245's Avatar
LMAO, the filter on this forum is halarious.
