tires: whats the difference..
Old Sep 9, 2009 | 09:06 PM
triton5.4FX4's Avatar
Looking to get BFG all terrains, size 285/70/17. Im getting them from sams club but on the site there is two options on the tire. These are the links..they are the same size and both BFG all terrains. What is the difference and which ones to i get. The first one is more expensive too.
http://www.samsclub.com/shopping/nav...=5&item=432422
http://www.samsclub.com/shopping/nav...=5&item=391522
Old Sep 9, 2009 | 09:12 PM
PHS79's Avatar
One is a load range D and the other is a E. Look at the last letter in each of the sizes. You will be fine with the D, less you over load your truck on a regular basis, then get the E
Old Sep 9, 2009 | 09:16 PM
Ryanmc86's Avatar
This is an 8 ply load range D and it looks like it has black side walls only
Tire Size: LT285/70R17D
Service Description: 121R
Sidewall: BSW-Black Side Wall
Material Number or MSPN: 14517
Rim Width (min. to max.): 7.5 - 9.0
Section Width: 11.0
Overall Diameter: 32.7
Tread Depth (32nds): 16
RPM: 636
Max Load: 3,197
and this is a load range E 10 ply tire and it has raised white letters on one side and black side wall on the other
Tire Size: LT285/70R17E
Service Description: 121Q
Sidewall: RWL
Material Number or MSPN: 25105
Section Width: 11.5 on 8.5
Overall Diameter: 32.8
RPM: 635
Max Load: 3195@80
The E is a little stiffer tire. I would go with the D unless you tow heavy alot. hope this helps
Old Sep 9, 2009 | 09:17 PM
thanks man
