Help!! Screwed up trailer wiring
Hello,
I have a new body style 2004 F150 Screw 4x4 5.4 lariat. Yesterday I installed a factory Ford 7pin /4pin trailer plug. It came with the factory plug in style wiring. I have no rear parking lamps or turn signals now. I have checked all the fuses and they are good. Where did I go wrong or what did I forget? This truck had a factory 4 pin flat on it that I removed to put the 7 pin/4 pin combo on. Please help.
Thanks,
Darrell
Thanks,
Darrell
Did you check the fuses for the truck signals and running lights??...there are separate fuses for both the truck and trailer signals /running lights
If all fuses are still good, I would say that the wiring is crossed or something is grounding out.
I have went through all the possible fuses. It's a factory Ford trailer plug so I don't think I could've crossed any wires. I may have to remove the wiring and strip all of the conduit off of it and look for broken/grounded wires.
Thanks,
Darrell
Thanks,
Darrell
Well here's the part # to the factory 7 pin/4 pin connector YL3Z-13A576-GB. I put the old factory 4 pin wiring back on and now everything is working again. The wiring harness I have must not be correct for my truck or it is manufactured wrong with the pins out of order. Does anyone have a proper "pin-out" for the 7pin/4pin that I'm trying to hook up?
Thanks,
Darrell
Thanks,
Darrell
I figured the issue out. This is the wrong part. the -GB is for 1998-2004. It looks like I need a -CA. From what I can find it looks like the -CA is for 2004-2008 models.
Thanks,
Darrell
Thanks,
Darrell
