2005 FX2 lower grille, Stealth style...(BIG PICS)
Old Sep 6, 2009 | 09:27 AM
john1102's Avatar
Looks awesome man
Old Sep 6, 2009 | 03:40 PM
ST Grey's Avatar
Nice work, really smoothed out the look of the whole front end.
Old Sep 6, 2009 | 04:11 PM
06 SANDSTONE's Avatar
looks good
Old Sep 6, 2009 | 04:22 PM
blackedoutV6's Avatar
nice finishing touch
i hate having a front plate too
Old Sep 6, 2009 | 05:24 PM
jdruzik's Avatar
Outstanding... Creates a very smooth and clean look... Nice job...
Old Sep 7, 2009 | 01:10 PM
It was just loosely in there the way I initially had it, so I re-did the mounting.
I took it off/apart and devised a way to make it more sturdy.
The fat tabs that the license plate screws go into held the grille up making it look bowed upwards slightly.
I took a sharpie to it and made some marks.
I cut away enough plastic with an X-acto knife to make a channel for the grille to nest into.
This took the pre-load out of the grille when the license plate bracket is mounted to the truck.
I then marked and drilled some holes in the license plate bracket and zip-tied the grille to the bracket to hold the grille more steady.
I then put the license plate bracket bracket with the grille attached into the bumper opening. It didn't look right. The grille was leaning back in the opening. I took it out and looked the assembly over. Decided to shim the bottom clocking the grille a bit. I cut the zip-ties and found some 1/4" airbag tubing from a previous project and cut a couple of 2" or so long pieces to wedge under the grille and bracket with zip-ties again.
Then I put it all back together and mounted it to the bumper. Now it looks right, and I'm satisfied with the final result. I just need to touch up the edges with some Krylon fusion and it's all good.
Old Sep 7, 2009 | 01:12 PM
87fiveoh254's Avatar
Much better! Great thinking to keep it in there securely.
Old Sep 7, 2009 | 03:45 PM
4x4wolf's Avatar
Grill looks really good
Old Sep 7, 2009 | 04:05 PM
mixedbreed's Avatar
not bad...
looks like a lot of GM products around your blue oval...
Old Sep 7, 2009 | 04:23 PM
Originally Posted by mixedbreed
not bad...
Just one. One 02 Impala, one 07 Kia Optima, one 85 Mazda RX-7, and one 91 Ford Probe GT.
Old Sep 7, 2009 | 06:53 PM
mixedbreed's Avatar
Holy crap! Are you an equal op buyer? Nice choice of sports cars.
Old Sep 7, 2009 | 07:16 PM
cherokee2871's Avatar
Grille looks great Stealth nice work brother
Old Sep 7, 2009 | 07:25 PM
The 2 old cars are permanent driveway residents as of now. I need to at least get rid of the rx.
