will 37's fit
will 37's fit
im trying to find pics and or info on whether or not 37x12.5x17's will fit on a leveled 07 FX4 with fiberglass fenders. i am willing to pull the bedsides as well if needed. thanks in advance
It would rub probably on the front valence and the rear, if you hit any bump or pothole it would compress into wheel wells you would need atleast a leveling kit and a body lift with the right wheel and backspacing and it may work with rubbing still. People have hard times getting 35's under a leveling kit, it can only be done with the right wheels and specs on those wheels, fitting 37's is an absolute no go imo.
Guest
Posts: n/a
Honestly man with a leveling kit and front glass yeah should fit. Trying to pull the rear glass is a pain on these trucks as they are spot welded it can be done just takes more time and work is all. Shoot I have a 2wd with bilstein leveling shocks on 1" and a 2.5" leveling kit and doesn't run with 4.75bs rims. Sure a lil severe on the angles but oh well. I am willing to bet you could fit 37's. As I am sure I can fit 37's on my setup.
