exhaust match up question
Old Aug 11, 2009 | 01:15 PM
rgecko23's Avatar
OK I got this guy from craigslist that has 2 magnaflow mufflers, si/so. they have a about 6" of pipe left over off the outlet. He also has the tips for it.
My question is, Would I have to get a y-pipe for my stock exhaust to mount up to it?, or can i just go straight out of the headers?
I am getting these for 100.00 so I dont want to put much more into it as i might as well buy new.
Old Aug 11, 2009 | 01:27 PM
rgecko23's Avatar
bump : )
Old Aug 11, 2009 | 02:24 PM
rgecko23's Avatar
no help?
Old Aug 11, 2009 | 06:02 PM
RoushF150's Avatar
You would have to split the exhaust somewhere, or cut the stock Y out. If you're not supercharged/turbocharged, I would go the former and split the exhaust 18 inches in front of the two mufflers, then run tailpipes back from the mufflers back.
Doing a DI/DO on an N/A motor will cause you to lose torque.
Old Aug 12, 2009 | 10:08 AM
rgecko23's Avatar
thanks i appreciate it. so it would basically be headers, cats, y pipie than another y pipe then back to the new mufflers, than out?
im not too knowledgeable when it comes to exhausts.
Old Aug 13, 2009 | 07:08 PM
RoushF150's Avatar
Yep. That'll do it. But check prices for bent aluminized pipe installed. It may actually cost less that the y pipe to split the single pipe to the 2 mufflers as those two sections would require about 8 bends total. Most of the way from the header pipes to the mufflers would be straight anyway.
Good luck!
