RANCHO 4" vs Superlift 4.5"
Old Aug 9, 2009 | 09:08 AM
jhndere's Avatar
Ok, I have a 2005 F150 FX4 Supercrew.
I am looking for a little more clearance so I dont want a 6" lift.
Stovetop has been corresponding with me on his Rancho lift which I really like.
Today I saw there is a 4.5" Superlift available also.
Can somebody give me a pros and cons of each?
The Superlift is obviously cheaper as are the shocks. But I dont need to go cheap for the sake of issues later.
I can afford either, but I dont want to overspend on a Rancho when the quality would have been just as good with the cheaper Superlift.
Is install harder for one or the other?
Thanks.
Old Aug 9, 2009 | 09:27 AM
05RedFX4's Avatar
What wheels do plan on running? Rancho is the only one that will allow you to run the factory wheels, even the 17's. That fact should help you decide.
jhndere's Avatar
After doing more research, I dont think the Superlift kit is going to work. Their site says it was developed with a 5.75" backspacing. I have 6" of backspacing. Which is also factory backspacing. It says the factory wheels will not work. So that makes me think my wheels will not work.
Old Aug 9, 2009 | 04:58 PM
NoLongerJeepin's Avatar
I would call superlift to verify. Superlift makes a good kit, a guy on here named Pimproar had it on his F150 and he had no complaints
Old Aug 9, 2009 | 06:44 PM
brianjwilson's Avatar
What size wheels do you have? I think the Superlift kit says that larger wheels (20's) can be run with more backspacing, and that factory wheels can be used in emergencies.
Someone can correct me if I'm wrong, but I believe the Rancho can use stock wheels because the front track is wider than the rear. Just what I have read.
Both seem to be good kits. The rancho comes with 4 shocks, where the superlift comes with a spacer for the front and different options for rear shocks.
Here is JesseRohr's truck with the superlift, I believe it was the 6" version.
https://www.f150online.com/forums/me...hots-f150.html
Here is what the superlift website says;
Requires new wheels with backspacing of 4.5” min. / 4.625” max. For 20” or larger wheels, max. backspacing is 5.5”. Can run factory spare tire / wheel in emergency situation.
