shocks or air bags first???
Old Aug 7, 2009 | 12:24 PM
labman1014's Avatar
i have an 08 f150 4x4 with 31k miles. i plan on adding some air bags in the near future to help level out while hooked up.
i still have the OEM shocks on and i know they are not the best out there. i was thinking of a set of bilsteins.
should i replace the shocks first in the rear or just go ahead and add the air bags?
also, if this matters, i plan on just doing the rear right now. mainly due to cost of the front set!!
Old Aug 7, 2009 | 12:27 PM
Truspeeder205's Avatar
shocks do not control the ride height they just dampen shock... i would do airbags, on mine i have the add a leaf, block and the racerunner shocks and it still squats... or there is always the option to change to a more heavy duty leaf spring such as deaver, atlas, or national
Old Aug 7, 2009 | 04:09 PM
05supercrew's Avatar
Do the shocks first, cheaper,easier to install, and you use your shocks all the time and at this point they are probably shot.
Old Aug 7, 2009 | 05:17 PM
jswd60's Avatar
Add some Monroe Sensatracs they will level off 1500 lbs.
I just added them to my truck with Hellwig helpers, and now no squatting.
I pull a 6 by 12 lawn trailer with about 2-2500 lbs daily.
This may help. What are you pulling?
Old Aug 7, 2009 | 05:59 PM
labman1014's Avatar
i tow a 7100# camper about 3k miles a year!!!
i dont need the helpers as when i use my WDH it gets my front back to original height, but the rear sags about an inch. i know shocks wont help the sag, but it will tame the last lil bit of bounce i have. i know the OEM are crap and wanted something better. are the monroes as good as the bilsteins??
Old Aug 7, 2009 | 06:43 PM
PHS79's Avatar
I would get the airbags. I got mine over 2 yrs ago and would not be without them!! They are one of, if not, the best thing that I have put on the truck. They made a world of difference while towing our Bobcats and tractor.
Old Aug 7, 2009 | 09:03 PM
jswd60's Avatar
I have never had Bilsteins, but these required me and my dad pushing them against the ground and then we had to tie them to install. I have a STX so it has a weak suspension. I could push the old shocks in all the way with no effort, and I know that they werent blown because my dad works at the Dealership and I went to parts dept, and they were the same.
If you have a stiffer suspension, then the shocks might not be the way to go, but if you need shocks anyway these have been great for me. I am also getting bags, just waiting until we get some new equipment and I actually need them, cuz now 2500 lbs is nothing.
Get the bags and take pics of the install.
Old Aug 7, 2009 | 09:27 PM
labman1014's Avatar
yea guess i will looking into the air bags. think i will go with the Air Lift set. they are about $70 cheaper and i heard they are mostly the same. just mount differently. i will let you know how it goes!!!
Old Aug 7, 2009 | 11:50 PM
tweeter's Avatar
i would do the air bags. lil expensive but well worth it. we pull a hagie 2100 sprayer with my dads 350 and it squats it only a lil bit with 80# in the bags. and it levels my truck with a full palet of seed in the bed
Old Aug 8, 2009 | 12:10 AM
jswd60's Avatar
How much is this going to make the bags?
Are you going to have a compressor or just lines?
I looked at the Air lift for my truck and it only shows 2000 lb of leveling.
The firestone ride rites had 5000 lb of leveling. I was looking at these a while ago and found them for 225 w/ free shipping. This is the way I am going to go because 2000 isnt much better than what I have and I could do way more with the 5000.
Old Aug 8, 2009 | 12:46 AM
labman1014's Avatar
i thought the 5000lb was for 3/4 ton and 1 ton trucks....
i found the air lifts for $177 with free shipping....and im just doing the bags. i will also get a 12v pump to keep in the truck to air the bags and to air TT tires if needed
edit---i just looked the firestone ride rites up again and they do 3200-5000lbs. where did you see them for $225??
Old Aug 8, 2009 | 09:00 AM
PHS79's Avatar
I would do the Firestone bags if I were you. Firestone makes the bags for class 8 trucks (semis, tandem axle dump trucks, ect) so they have been making bags for a long time. Also the bags for the F150 are rated at 5000 lbs. I have had over 3500 lbs in my truck and they bags handled it fine with only 80ish psi in them. I want to put a in cab gauge set up in my truck, but until I do that I have just been using a small compact air compressor that fits under the rear seat.
Edit--Another thing that you can do is check the classifieds on here. Every once in a while someone will list a pair of bags for sale, I bought mine off a member for $180 shipped to my door and they were only 6 months old.
Old Aug 8, 2009 | 09:34 AM
labman1014's Avatar
cool deal!!! thanks!!
Old Aug 8, 2009 | 02:50 PM
jswd60's Avatar
Street side auto
http://www.streetsideauto.com/produc...&ResetAPQ=True
245+ free ship
coupon code
ssawinner09
=220.25
