Hard shift and clunk between gears
Hey guys,
Just had a remanu. upgraded tranny put in about 800 miles ago. Driving around town, I've got some real hard shifts that generate a heavy "clunk" feeling throughout the truck. The entire truck jolts for a split second, like a really hard shift.
This generally only happens at low RPMS in the 20-30 mph range, or when downshifting into second.
Any ideas? Normal for a tough tranny?
Thanks.
Thanks.
eh, i dont know. ill go and wiggle the shaft around and what not, but im not getting any noises other than the clunk. i know that they usually make a screeching sound if they go bad, and also, i dont have any jerking from D into Reverse.
i went and did the whole "put truck in neutral and pull on drive shaft thing" and the drive shaft itself will twist maybe a 1/4 quarter inch, of play. but nothing up and down or side to side at the joints. the twist also follows through to the transmission, so I think this is normal movement.
any ideas?
any ideas?
any ideas?
any ideas?
mine is a one piece driveshaft.
the play is definitely coming from the tranny... or torque converter... whatever it directly attaches to in the front.
so with that said... what does that mean? i have an appt on monday to have it all looked at.
