Center console part question
Good evening,
I'm looking to replace the rubber piece on my 2004 F150 FX4 on the center console around the cup holders. The rubber started to peel off the foam under it. I don't want to purchase the whole center jump seat. See a picture here:
Thanks so much for the help and suggestions!
David
David
center console rubber around cup holders - fix :)
So i had an idea about a way to fix the rubber around the cup holders on my 2004 F-150 FX4..tried it and it worked. I had some of the insulating foam that comes in the can to expand around windows and doors. I took apart the drop down console and released the rubber piece with the hard plastic backing. I then pulled the rubber off the plastic, tore the foam out of the inside, then dry fit everything so it would be like I wanted it. I then sprayed the insulating foam inside and put everything back together and threw some tape to hold it in place til the foam expanded and everything dried. I'll be putting it back in the truck this afternoon but from what I can tell it worked very well. So for those of you who have that piece that is peeling up this may be a solution for you.
