Metal shaving sound video
Old Jul 18, 2009 | 10:48 AM
05RedFX4's Avatar
Originally Posted by Trogdors4x4
I replaced the solenoid like last month. I have 4x4 it works but there could be a slow leak i suppose. It would have to be the drivers side. Could this affect both sides if one was leaking?
Yep, depending on where the leak is.
There is also check valves in line between the solenoid and the hubs to prevent the hubs from trying to engage during temporary low vac during accel or under load. When they go bad, your hubs will try to engage during accel. Thats what mine did, they had to replace the solenoid, both check valves, and a complete hub assy.
Old Jul 18, 2009 | 01:01 PM
Trogdors4x4's Avatar
I just took it around the block in 4x4 and I couldn't get it to make that sound. I'm guessing my next step is to check out the check valves.
